Load Step: DSLOAD
In the DSLOAD dialog, define the *DSLOAD card on Abaqus surfaces (*SURFACE).
To open the dialog in the Load Step window, select DSLOAD from the tree and a Load collector from the table.
You can use Abaqus Contact Manager to create Abaqus surfaces.
Load Step: DSLOAD: Define Tab
In the Define tab, define *DSLOAD card on Abaqus surfaces (*SURFACE).
There are two types of DSLOAD available: Pressure and hydro pressure.
This dialog also contains a table for data line input. The table changes depending on the DSLOAD type selected.
- Default (Pressure) type
Table 1. Column Description Surface The name of the Abaquss surface. Surfaces are added and deleted in this column using → or ←, respectively. Label The labels of pressure load. The available labels are P, PNU, and VP. Magnitude The magnitude of the load. - Hydro pressure type
Table 2. Column Description Surface The name of the Abaqus surface. Surfaces are added and deleted in this column using → or ←, respectively. Label The labels of the hydrostatic pressure. The available label is HP. Magnitude The magnitude of the load. Zero press Z-coordinate of zero pressure level in three-dimensional or axisymmetric cases; Y-coordinate of zero pressure level in two-dimensional cases. Press point Z-coordinate of the point at which the pressure is defined in three-dimensional or axisymmetric cases; Y-coordinate of the point at which the pressure is defined in two-dimensional cases.
| Button | Action |
| Review Surfaces | Reviews the selected surface by highlighting them in the HyperMesh graphics. Right-click Review to clear the review selections. |
| Create/Edit Surface.. | Opens a message with information about surface definition in HyperMesh. |
| → | Add the selected surface from the drop-down menu to the data line table on the right. |
| ← | Delete the selected surface from the data line table. |
| Review | Reviews the selected surface in the data line table. Right-click Review to clear the highlighted selections. |
| Update | Updates the HyperMesh database with the data lines defined in the table. By default, HyperMesh does not create a display for loads defined with sets. |
For tips on entering information and navigating in the Define tab, see Step Manager Tab Environment.
Load Step: DSLOAD: Delete Tab
In the Delete tab, delete *DSLOAD and other loads.
| Option | Description |
| All loads in current collector | The Delete button deletes all the loads from the current load collector. |
| All 'DSLOAD' in current collector | The Delete button deletes only *DSLOAD loads from the current load collector. |
| By selection | The Pick Loads button opens the HyperMesh
load selector panel. Pick the loads you want to delete and click
proceed. The corresponding Reset button resets the selected loads. The Delete button deletes the selected loads. |
Load Step: DSLOAD: Parameter Tab
In the Parameter tab, define optional parameters for the *DSLOAD card.
The supported parameters include: Amplitude, OP, Load Case, Cyclic Mode and Region Type.
Click Update to activate the optional parameter selection in the HyperMesh database.
