Load: Load Command
Command ElementThe Load_Command command reads the command block from a specified MotionSolve XML file and executes the command elements.
<Load_Command
Command_File = "valid_file_name.xml"
/>Attributes
- Command_File
- The name of the MotionSolve XML file to be loaded.
The following example demonstrates using the Load_Command to load a MotionSolve XML file, called cmd.xml and then executing the three simulate commands it contains.
<Command
<Load_Model
model_file = "save1.xml"
result_file = "output.mrf"
anima_file = "output.h3d"
<Simulate
analysis_type = "Transient"
end_time = "5."
print_interval = "0.01"
<Load_Command
command_file = "cmd.xml"
<Simulate
end_time = "10."
</Command>
The contents of the file cmd.xml are as follows.
<Command>
<Simulate
end_time = "6."
<Simulate
end_time = "7."
<Simulate
end_time = "8."
</Command>
- Any general MotionSolve XML file can be specified. MotionSolve will read only the command block from the specified file.
