Force: Two Body Vector
Command ElementModifies a Force_Vector_TwoBody force element.
<Force_Vector_TwoBody
id = "integer"
i_marker_id = "integer"
j_floating_marker_id = "integer"
ref_marker_id = "integer"
{ type = "forceonly"
fx_expression = "motionsolve_expression"
fy_expression = "motionsolve_expression"
fz_expression = "motionsolve_expression"
usrsub_dll_name = "valid_path_name"
usrsub_param_string = "USER([[par_1[,...][,par_n]])"
usrsub_fnc_name = "valid_function_name"
type = "torqueonly"
{ tx_expression = "motionsolve_expression"
ty_expression = "motionsolve_expression"
tz_expression = "motionsolve_expression"
type = "forceandtorque"
{ fx_expression = "motionsolve_expression"
Attributes
- id
- Element identification number (integer>0). This number is unique among all Force_Vector_TwoBody elements.
- i_marker_id
- Modifies the Reference_Marker at which the force is applied. This is designated as the point of application of the force.
- j_floating_marker_id
- Modifies the Reference_Marker at which an equal and opposite reaction force is applied. This marker is moved around on the parent body so that it is always superimposed on i_marker_id. Such a construct allows Newton's third law to be automatically fulfilled. Note j_floating_marker_id may belong to rigid bodies or point masses only. They may not belong to flexible bodies.
- ref_marker_id
- Modifies the Reference_Marker whose coordinate system is used as the basis for defining the components of the force vector.
- fx_expression, fy_expression, fz_expression
- Modifies any of the three components of the force vector as function expressions.
- tx_expression, ty_expression, tz_expression
- Modifies any of the three components of the torque vector as function expressions.
- usrsub_dll_name
- Modifies the path and name of the DLL or shared library containing the user subroutine. MotionSolve uses this information to load the user subroutine in the DLL at run time.
- usrsub_param_string
Modifies the list of parameters that are passed from the data file to the user defined subroutine. The name of the user-subroutine depends on the type of the element.
"FORCEONLY": defaults to VFOSUB
"TORQUEEONLY": defaults to VTOSUB
"FORCEANDTORQUE": defaults to GFOSUB
- usersub_fnc_name
- Modifies an alternative name for the user subroutine VFOSUB or VTOSUB or GFOSUB.
id = "30101"
fx_expression = "2"
fy_expression = "-1"
fz_expression = "-2"
id = "30101"
tx_expression = "1"
ty_expression = "0"
tz_expression = "0"
- The type of the Force_Vector_TwoBody cannot be changed in the command.
- The way in which the force magnitude is specified cannot be changed. For example, a force specified in a model element with expressions cannot be modified using a user subroutine and vice versa.
