Force: Joint Friction
Command ElementThe Force_JointFriction command can be used to modify the parameters of the model element.
<Force_JointFriction
id = "integer"
[ mu_static = "real" ]
[ mu_dynamic = "real" ]
[ max_stiction_deform = "real" ]
[ stiction_trans_vel = "real"]
[ inputs = "4-bit integer" ]
[ torque_preload = "real" ]
[ friction_arm = "real" ]
[ bending_reaction_arm = "real" ]
[ pin_radius = "real" ]
/><Force_JointFriction
id = "integer"
[ ball_radius = "real" ]
id = "integer"
[ stiction_trans_vel = "real" ]
[ inputs = "4-bit integer " ]
[ force_preload = "real" ]
[ reaction_arm = "real" ]
[ initial_overlap = "real" ]
id = "integer"
id = "integer"
[ max_stiction_deform = "real"]
/>Attributes
- id
- Element identification number, (integer > 0). This number is unique among all Force_JointFriction elements.
- mu_static
- Specifies the static friction coefficient, (μs), in the joint.
- mu_dynamic
- Specifies the dynamic friction coefficient, (μd), in the joint.
- max_stiction_deform
- Specifies the maximum deformation that can occur in a joint for static friction or stiction regime.
- stiction_trans_vel
- Real value of the absolute velocity below, which the friction transitions from dynamic friction to static friction.
- inputs
- A 4-bit integer value that specifies the input forces to the friction model. By default, all the preload and joint reaction forces are included. Valid values are 0 or 1 for each bit.
- force_preload
- Specifies the preload friction force for Translational and Cylindrical joints.
- torque_preload
- Specifies the preload friction torque for Revolute, Cylindrical, Universal and Spherical joints.
- friction_arm
- Specifies the moment arm used to compute axial friction torque in revolute, universal joints.
- reaction_arm
- Specifies the moment arm of the reaction torque about the Translation joint axial axes.
- bending_reaction_arm
- Specifies the moment arm to compute the bending moment in Revolute, Hooke and Universal joints.
- pin_radius
- Specifies the radius of the pin for Revolute, Cylindrical, Hooke and Universal joints.
- ball_radius
- Specifies the radius of the Spherical joint.
- initial_overlap
- Specifies the initial overlap of the sliding parts in Translation and Cylindrical joints.
- overlap_delta
- Specifies friction characteristics in the sliding joint.
