Modal Participation - Load
Perform file and result selection.
- File selection
- From the , select an OptiStruct .h3d file or an MSC Nastran .f06/.pch file and click Load. Upon reading the file, the Result selection fields are populated.
- Result selection
- The following fields are available under Result selection. Once the
result selection options are complete, select Load Response to further
investigate the participations.
- Subcase
- Select an analysis subcase.
- Result type
- Select a participation result type. Options include:
- System Structure Modal Participation to Acoustic Grid
- System Fluid Modal Participation to Acoustic Grid
- System Structure Modal Participation to Panel
- System Structure Modal Participation to Structure Grid
- Component Structure Modal Participation to Acoustic Grid
- Component Fluid Modal Participation to Acoustic Grid
- Component Structure Modal Participation to Structure Grid
- Panel Participation to Acoustic Grid
- Response ID
- Grid ID of the response for which Modal/Panel participation results are available. Select one from the list.
- Response label (optional)
- Enter a label that describes the response, for example "Driver’s Ear".
- Direction component
- X, Y, or Z.
- Result set (optional)
- Select from Structural Mode, Acoustic Mode, Panels
- Display Options
- The Display Options dialog allows you to customize the response plot, including scale, weighting, and the plot layout.
- Load Response
- Once the result selection options are complete, select Load Response to display the file data.
