HyperWorks NVH
HyperWorks NVH
  1. Home
  2. Post-Processing and Diagnostics
    Define radiation conditions and create emissivity models.
  3. Load an NVH Utility
  • What's New
  • Get Started
  • Tutorials
  • Assembly
  • Prepare Module
  • Analysis
  • Post-Processing and Diagnostics
Index
HyperWorks NVH
HyperWorks NVH
  • What's New
    View new features for NVH 2021.
  • Get Started
  • Tutorials
    Discover NVH functionality with interactive tutorials.
  • Assembly
  • Prepare Module
    Create, organize and manage the CAE parts.
  • Analysis
    Set up the simulation model, materials, domains and boundaries.
    • Load an NVH Utility
    • Integrated Diagnostics
      Calculate a response, perform contribution analysis, plot results, and perform diagnostic studies and study response changes.
    • Modal Participation
      Plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
    • Grid Participation
      The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
    • Energy Distribution
      Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
    • Transfer Path Analysis
      Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
    • Design Sensitivity Analysis
      Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
    • Order Analysis
      Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
    • Modal FRF
      Calculate a frequency response based on modal results.
    • Model Correlation
      The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
    • Radiated Sound
      The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
    • Global Modes
      Identifies global modes from an OptiStruct or Nastran modal analysis.
    • Mount Optimization
      Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
    • Optimization, RBDO
      Optimizes sensitive parameters for multiple sample analysis results using the RBDO approach.
    • Multiple Sample Analysis
      Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
    • Display Options
      Customize plots using the following options
    • Filter Contributors
      Filters contributors to a smaller set of data.
HyperWorks NVH
HyperWorks NVH
  1. Home
  • What's New
  • Get Started
  • Tutorials
  • Assembly
  • Prepare Module
  • Analysis
Index
Load an NVH Utility
From the Post ribbon, select an NVH utility tool to display the NVH-Utilities Browser and start using the tool. The NVH Utilities include:
Tool NVH Utility
Modal/Panel Participation
Grid Participation
Energy Distribution
Order Analysis
Modal FRF
Correlation
Radiated Sound
Global Modes
Mount Optimization
MSA Structures
MSA Loads
MSA RBDO
