HWD-0092: Create Reports in Batch Mode
In this tutorial, you will learn how to generate reports using Batch Mode with previously created report template.
The files used in this tutorial are located here:
<installation_directory>/tutorials/hwdesktop/mv_hv_hg/publish_reports/
In this exercise, use the reuse feature and batch mode to create and export Document and Presentation reports.
Submit Batch Execution Commands
In this step, you will run a set of commands in the Command Prompt to execute and export a Presentation report in batch mode.
- Delete outputs and save as a clean tpl.
- Remove interactive mode option from the Entity Overview modules to avoid any pop ups.
