Delete Shapes
Delete selected shapes.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing. These constraints are always valid for all available morphing approaches.
Use the Free tool to morph mesh by moving nodes, faces, and edges or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, or edges.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Create and apply morphing shapes.
Record node movements using other HyperWorks tools and save them as a shape.
Animate selected shapes.
Apply a scale factor to change to the magnitude of the morphed shape.
Convert a shape to node perturbations, handle perturbations, an mvol shape, forces, temperatures, pressures, or displacements.
Import saved shapes from a file.
Export selected shapes.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
