NX Reader
NX import is available through two different readers: UGOpen native reader and a third-party non-native reader.
View new features for HyperWorks 2021.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
Learn about the CAD readers supported by HyperWorks and the options available for importing CAD geometry data.
CAD readers supported by HyperWorks.
Use the CATIA Composites Link option to import drape data. This method is separate from the CATIA reader, where drape data is not imported.
The FiberSim reader is supported for Nastran and OptiStruct user profiles.
The NX reader utilizes the UGOpen library to read files from NX.
The NX Third Party reader does not need a valid NX installation or license to access these libraries.
CAD readers provide options for processing data during import.
Each reader reads the CAD file and sends the geometry information to HyperWorks. When a CAD file is read, a .msg file is created (or appended to) in the current working directory.
Learn about possible difficulties you may encounter during CAD import.
The metadata names generated by the CAD readers are composed of a general prefix followed by a metadata specific name.
The prefix is specified using the @MetadataPrefix option in each _reader.ini file.
Import FE models for supported solver interfaces.
Learn about importing connector files.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
