View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Use the 1D Mesh: Create tool to create 1D elements on lines or nodes.
Use the 1D Mesh: Align tool to reorder the N1 to N2 sequence of 1D element nodes.
Use the 1D Mesh: Orient tool to define bar2 orientation vectors or orientation nodes.
Use the 1D Mesh: Offset tool to manually set offsets or adjust beams on plates.
Use the 1D Mesh: Pins tool to edit and release degrees of freedom.
Use the 1D Mesh: Review tool to plot area moments of inertia and stiffness.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Beamsection collectors collect and organize beamsections and are used in HyperBeam to organize 1D beam section data.
Beamsection entities store 1D beam cross-section data.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
