HyperWorks
HyperWorks
2021
  1. Home
  2. Results Data
  3. Create Entities
  4. Create Derived Results
    The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
  5. HyperWorks Result Math
    A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
  6. Result Math Reference Guide
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021
HyperWorks
  • What's New
    View new features for HyperWorks 2021.
  • Get Started
  • Video Tutorials
    Set up your sessions in HyperWorks and create report templates.
  • Geometry
  • Meshing
  • Elements
  • Morph
    Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Design Space
    The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
  • Design Explorer
  • Aerospace
    Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
  • Aeroelasticity
  • Marine
    Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
    Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Panels
  • Results Data
    • Working with Models
    • Animate and Visualize Results
    • Create Entities
      • Create Derived Results
        • Output Parameters
          The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
        • Operators
          The list of available operators is controlled by the template file selected when loading a model and result, and it can be modified by adding or removing <using /> statements in the template.
        • Table Selection
          Once an operator is selected, tables must be selected to form the input.
        • Default Arguments
        • Constant Value Arguments
          When an argument is passed as a constant, it is converted to a constant value table by the Expression Builder.
        • Additional Resources
          Additional resources can be attached to the analysis for the purpose of adding new tables.
        • Authoring Expressions
          The Expression Builder uses a Templex-like syntax to author Result Math XML commands.
        • HyperWorks Result Math
          • Results Browser
          • Result Math Templates
            Various Result Math templates are available whenever a model/result pair is loaded into HyperView.
          • Creating New Datatypes
          • Operator Library Reference
            Result Math operators are contained within a set of related functions organized by category or industry vertical known as libraries.
          • Error Handling
          • Known Limitations
          • Result Math Reference Guide
      • Derived Load Cases
        The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
      • Systems
        Create your own user defined coordinate systems or select result coordinate systems.
      • FLD
        Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
      • CFD Post-Processing
        HyperView offers CFD post-processing capabilities for a large class of industrial applications.
      • Tracking
        Use the Tracking tool to track any entity during animation.
      • Sets
        Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
    • Query Data
    • Annotate Models
    • Transform Models
    • Overlay Images/Videos
    • Rendering Models
    • Additional Tools for Post-Processing
    • Profiles
    • Preferences Menu
      From the Preferences menu, you can access the Options dialog.
    • Display/Visualization Options
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
HyperWorks
HyperWorks
2021
  1. Home
  2. Results Data
  3. Create Entities
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
See the Result Math Reference Guide for additional information.
