system delete
Delete a system.
system delete all
system delete <label>
Arguments
- all
- Delete all systems.
- <label>
- Deletes a specific system(s) from the displayed list.
system delete allsystem delete "System 2"View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Create a coordinate system.
Delete a system.
Rename a system.
Select the method by which to create the coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
Delete a system.
Delete a system.
system delete all
system delete allsystem delete "System 2"(c) 2021. Altair Engineering Inc. All Rights Reserved.
