sset delete
Deletes a selection set.
sset delete <name>
Argument
- <name>
- The name of the set to delete.
sset delete "Orphan Nodes"sset delete "2D Set" ,"1D Set"View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Adds entities to a selection set.
Creates an empty selection set.
Creates a set with displayed entities.
Exports sets to a file.
Imports a set from a file.
Renames a selection set.
Removes entities from a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
sset delete <name>
sset delete "Orphan Nodes"sset delete "2D Set" ,"1D Set"(c) 2021. Altair Engineering Inc. All Rights Reserved.
