show model
Shows all or parts of a model.
show model all
show model <id>
Arguments
- all
- Show all models.
- <id>
- Show models based on IDs. For example,
(1,2,4).
Examples
show model allshow model 5View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Shows all entities in the active model.
Shows components in the active model.
Shows elements in the active model.
Shows legends.
Shows marked entities.
Shows selection sets.
Shows systems.
Shows a tracking system.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
show model all
show model <id>
(1,2,4).show model allshow model 5(c) 2021. Altair Engineering Inc. All Rights Reserved.
