save session
Saves the current session.
save session <filename>
Arguments
- <filename>
- Use the file browser to enter the session filename and select a directory to save the session to.
save session C:\working_directory\MySession.mvwView new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
save session C:\working_directory\MySession.mvw(c) 2021. Altair Engineering Inc. All Rights Reserved.
