result tensor legendmaxenabled
Enables the legend's maximum value.
result tensor legendmaxenabled <true/false>
Arguments
- <true/false>
- Enables/disables the legend's maximum value.
result tensor legendmaxenabled trueView new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
ClassicCreate and manage the contour plot.
Makes a subcase current.
ClassicCreate and manage tensor plots.
Clears the tensor plot and returns the model to its original state.
Changes the tensor color by direction.
Changes the value display.
Clears the tensor plot from the graphics window.
Edits the tensor plot legend properties.
Defines the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
ClassicLoads and plots the tensor data type.
The multiplier for scaling the result values.
Displays the current tensor plot in the modeling window.
ClassicCreate and manage vector plots.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
Result loading.
result tensor legendmaxenabled true(c) 2021. Altair Engineering Inc. All Rights Reserved.
