mark sset
Marks entities by selection set.
mark sset <name>
mark sset sset <name>
Arguments
- <name>
- The name of the selection set.
- sset
- Clear by the selection set name.
mark sset sset Set_3.1mark sset "0D Set"View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
mark sset <name>
mark sset sset Set_3.1mark sset "0D Set"(c) 2021. Altair Engineering Inc. All Rights Reserved.
