hwd model
HyperView model options.
hwd model makecurrent <model id>
Arguments
- makecurrent
- Change the active model in the active window.
hwd model makecurrent 1View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
hwd model makecurrent 1(c) 2021. Altair Engineering Inc. All Rights Reserved.
