delete parameterizedsession
Deletes an already-loaded session that contains parameters.
delete parameterizesession <template name>
Arguments
- <template name>
- The template name.
delete parameterizedsession report_1View new features for HyperWorks Desktop 2021.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Deletes the model.
Clears all data from the current client (window).
Deletes the current session.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
delete parameterizedsession report_1(c) 2021. Altair Engineering Inc. All Rights Reserved.
