config section
Set planar and spherical section cut options.
config section planar <name>=<value>
config section spherical <name>=<value>
Arguments
- planar
- Define the planar section cut options.
- base=<value value value>
- Enter user-defined x, y, and z coordinates to check the current position of the section cut.
- clipabove=<true/false>
- Select true or false.
- clipelements=<true/false>
- Display the elements of the clipped part of the model.
- crosssectiononly=<true/false>
- Display a cross section of the section cut.
- deformable=<true/false>
- Make the deform mode deformable.
- grid=<true/false>
- Display the gridlines.
- gridlinespacex=<value>
- Enter a value to change the x position of the graphical manipulator on the grid line grid.
- gridlinespacey=<value>
- Enter a value to change the y position of the graphical manipulator on the grid line grid.
- gridtext=<true/false>
- Display the grid line text value in the modeling window.
- gridtextprecision=<1-10>
- Increment the current grid line text value from 0 to 10 decimal points.
- normal=<value value value>
- Specify a plane normal to the screen by picking a base node on the model.
- orientation=<3nodes/normaltoscreen/xaxis/yaxis/zaxis>
- Define the orientation. Options include:
- 3nodes
- normaltoscreen
- xaxis
- yaxis
- zaxis
- sectioncolor=<RBG/label>
- Change the section cut color by entering RGB values or selecting a color from the list.
- showsectioncolor=<true/false>
- Display the section cut color.
- visibility=<true/false>
- Display the section cut in the modeling window.
- width=<section width>
- Adjust the width of the cross section by entering a value.
- spherical
- Define the spherical section cut options.
- center=<value value value>
- Enter the x, y, and z coordinates of the base point of the section cut.
- centernode=<node id>
- Allows you to adjust the position of the base point of the section cut to the center node.
- clipinside=<true/false>
- Displays the cross section of the section cut inside the sphere.
- Allow the section cut to be deformed, along with the components, during animation.
- radius=<value>
- Enter a value to specify the radius of the spherical section cut.
- sphere=<true/false>
- Displays a sphere.
config section spherical visibility=true showsectioncolor=true sectioncolor=Cyan clipinside=true centernode=60Comments
Default values specified by this command will be used by all spherical and planar section cuts.
