Project Vectors on a Cross Section Plane
Open the Vector panel in the following ways:
- From the Results toolbar, click Vector
. - Select Plot > Vector from the Results menu.
From the Vector panel, click the Section tab (located in
the middle of the panel).
Note: The Section options will only be enabled if all of the following conditions are met:
- A section cut has been applied to the model.
- The Selection input collector is set to Sections.
- The Resolved in system is set to Global.
- Activate the Projected option to project the vectors to the cross section plane.
Activate the Evenly distributed option to evenly
distribute the vectors on a cross section.
- Enter the desired number of rows that will be used to evenly distribute the vectors.
- Enter the desired number of columns that will be used to evenly distribute the vectors.
Note: The Evenly distributed option must be activated in order to enable these options.Tip: You can also use the command layer to change the updating policy for the vector plot on the cross section.
