Create Plot Style
Open the Vector panel in the following ways:
- From the Results toolbar, click Vector
. - Select Plot > Vector from the Results menu.
From the Vector panel, click the Create Plot Style
button.
Tthe Create/Update Vector Plot Style dialog opens, which allows you to create or update a result plot style based on the current settings of the vector.Note: A vector plot needs to be current in order to create a new style or modify an existing one.All the settings of the vector plot (resolved in systems, default data type/components, display options, legend, etc.) are captured in the named style.
