Overlay Result Display
Open the Vector panel in the following ways:
- From the Results toolbar, click Vector
. - Select Plot > Vector from the Results menu.
From the Vector panel, under Result display control, activate the
Overlay result display option.
Overlays the vector, tensor, and contour results in the same window.Note: If all results are displayed simultaneously, available memory may be affected.
