Scale Element Thickness
Scale the thickness of elements in your model.
Scale Thickness Behavior
Solver interface specific behavior for scaling the thickness of elements.
LS-DYNA
You can only perform thickness operations on *ELEMENT_SHELL_THICKNESS and *ELEMENT_SHELL_COMPOSITES elements. If the card image of elements is *ELEMENT_SHELL_COMPOSITES, then the total thickness will be calculated using the sum of all the THICK attributes. Scaling will be done in proportion with all the thickness attributes.
For example, consider the number of plies is four and the THICK attributes are: THICK(1) = 2, THICK(2) = 4, THICK(3) = 6, THICK(4) = 8. The total thickness will equal 20. If you add two to this thickness, then after scaling the thickness of these attributes will be: THICK(1) = 2.2, THICK(2) = 4.4, THICK(3) = 6.6, and THICK(4) = 8.8. After scaling, the total thickness will become 22.
Radioss
You can only perform thickness operations on /SHELL/ and /INISHE cards. /INISHE supports the following three cards: /INISHE/EPSP_F, /NISHE/STRA_F, and /INISHE/STRS_F. If the thickness attribute of /SHELL is not defined and /INISHE is not available, then the thickness will either be defined by the Property or Component. As of now, the thickness of Property and Component entities cannot be assigned using the Scale Thickness tool, therefore thickness will be assigned to the /SHELL thickness attribute.
PAM-CRASH 2G
You can perform thickness operations on elements with card image SHELL and TSHEL for the attribute "T". You also perform thickness operations on components that have the card image SHELL, TSHEL, or MEMBR for the attribute H. There is no impact on thickness for the TCONT contact.
