Multibody Planes
MADYMO
| Card | Description |
| SURFACE.PLANE | Rectangular plane. multibody = BODY N1 = POINT_1 N2 = POINT_2 N3 = POINT_3 To create a SURFACE under the SYSTEM.REF_SPACE, a reference to a null body must be selected because a reference to a multibody is required when creating a multibody plane. A null body can be created like any other BODY (card image is not relevant and should not be used), Nullbody should be put under the SYSTEM.REF_SPACE assembly. |
