Show, Hide, and Isolate Entities
Turn the display of entities on and off in the modeling window.
Show, Hide, and Isolate Using Context Menus
Show and Isolate Nearby Entities
Supported target entities: Elements, components, systems, vectors, loads, and equations.
Show and Hide Using Browser Icons
Show, Hide, and Isolate Using the Show/Hide Tool
Activate the Show/Hide tool
on the View Controls toolbar.
Select entities to show or hide.
- Activate or deactivate the checkboxes in the microdialog.The microdialog lists the available entity types in your model that you can show/hide. The checkbox next to each type of entity indicates its current display state. A checked checkbox indicates that all of the entities of that type are displayed. A checkbox with a line indicates some of the entities of that type are displayed, but not all. An empty checkbox indicates that there are no entities of that type displayed.Tip: Click All/None/Only to quickly change the display state of multiple entity types.
Figure 2. - Use the Show/Hide
guide bar for more precise control.
- Select an entity type using the entity selector.
- Click
to define
additional options. - Left-click entities to hide them,
Shift + left-click to show them, or use
of the show/hide icons on the guide bar.
- Show all of the current entity type.
- Show none of the current entity type.
- Reverse the display of the current entity type.
- Isolate selection only or all of the current entity type.
Show, Hide, and Isolate Using the Mask Browser
Keyboard Shortcuts & Mouse Controls
| To do this | Press |
| Enter and exit the Show/Hide tool | D |
| Show selection If there is no selection, show all of the current entity type |
A |
| Show entire model | Shift + A |
| Hide selection If there is no selection, hide all of the current entity type |
H |
| Hide and clear selection (Idle mode only) |
Ctrl + H |
| Isolate selection and turn off all other entity types If there is no selection, isolate the current entity type |
I Middle Mouse Click with entities selected (Show/Hide tool only)
Tip: Middle mouse click again to reverse the isolated
display. This is useful if you want to append to your selection and isolate more
entities.
| Isolate selection and retain all other entity types (Show/Hide tool only) |
Shift + I |
| Show entities adjacent to selection If there is no selection, show adjacent entities that are the same type as the entity selector (Idle mode only) |
J |
| Reverse display of selection If there is no selection, reverse the display of the current entity type |
R |
| Switch the display from mesh only, geometry only, or both (Idle mode only) |
G |
| Toggle on/off IDs of a selection (Idle mode only) |
Q |
