HyperGraph 3D Menus
The HyperGraph 3D menus provide quick access to panels and tools.
The following menus are available in HyperGraph 3D:
Curves
From the Curves menu in HyperGraph 3D, you can access the
following panels:
| Icon | Panel | Behavior |
| Define Curves | Individual curves can be edited using the Define Curves panel. | |
| Waterfall | Create waterfall plots from XY Force Response data and input pulses. | |
| Datum Planes | Insert reference datum planes to plots. | |
| Data Query | Uses vertical cutting surfaces for viewing and plotting non-planer cross sections. | |
| Curve Attributes | Define curve attributes, such as line style, color, and weight as well as symbol style, color, and data attributes. | |
| Coordinate Info | Retrieve individual point data on any curve in the active window. |
Annotations
Preferences
From the Preferences menu, you can access Export Settings.
- Export Settings
- Select a file type to define the parameters for each:
- AMF
- AVI
- H3D
- JPEG
- GIF
- PPT Options
- See the Export Settings topic in the HyperWorks Desktop Overview help for more information.
