HyperGraph 3D Panels
The HyperGraph 3D panels allow you to manage, review, and analyze 3-D plots such as waterfall, surface, and 3-D line data.
| Icon | Panel | Description |
| Define Curves | You can edit individual curves using the Define Curves panel. The curve calculator is located on the Define Curves panel. | |
| Waterfall | Use the Waterfall panel to create waterfall plots from XY force response data and input pulses. | |
| Datum Planes | Use the Datum Planes panel to insert reference datum planes to plots. | |
| Data Query | Use the Data Query panel to vertically cutt surfaces for viewing and plotting non-planer cross sections. | |
| Curve Attributes | Use the Curve Attributes panel to define curve attributes, such as line style, color, and weight as well as symbol style, color, and data attributes. | |
| Coordinate Info | From the Coordinate Info panel, you can retrieve individual point data on any curve in the active window. | |
| Axes | From the Axes panel, you can add axes to curves and modify their attributes. | |
| Notes | From the Notes panel, you can add curve annotations to your plots. |
