Engineering Solutions
2021
  1. Home
  2. Model Build and Assembly
  3. Manage Parts
  4. Manage Representations
  5. Delete Representations
    Part representations can be deleted from the current HyperMesh session and from the Part Library.
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Squeak and Rattle Director
  • Crash
  • CFD
  • Drop Test
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Build and Assembly
  • Model Verification
  • Model Setup
  • Morphing
  • Optimization
  • Conversion Between Solver Formats
  • XY Plotting
  • Post-Processing Analysis
Index
2021
  • What's New
    View new features for Engineering Solutions 2021.
  • Get Started
    HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
  • Tutorials
    Discover Engineering Solutions functionality with interactive tutorials.
  • NVH
    Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
    Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Crash
    The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
  • CFD
    HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
  • Drop Test
    The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
  • Aerospace
    Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
    Solver interfaces supported in Engineering Solutions.
  • CAD Interfaces
  • Browsers
    Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
  • Panels
  • Geometry
  • Meshing
  • Connectors
    • Manage Parts
      • About Parts, Part Assemblies, Part Instances
        A part is an engineering representation of a physical part, and a part assembly is a group of part assemblies and/or parts. Part Instances, which are recognized from PDM, are automatically converted to Part Instances on import into HyperMesh.
      • Create Parts, Part Assemblies, and Part Instances
        Only CAE parts and part assemblies can be manually created in HyperMesh. PDM parts and part assemblies must be imported into HyperMesh.
      • Import Parts, Part Assemblies, and Part Instances
      • Organize Part Assemblies and Parts
        Organize part assemblies, parts, and components in your model.
      • Save Assemblies as HyperMesh Binary Files
        The part assembly can be saved as a self-contained binary file, which will include the part assembly based hierarchy and attributes such as components, properties, and materials.
      • Manage Representations
        • About Representations
          The CAD representation is typically the original source of information of what a physical part will look like. It forms the basis of the Common representation, which in turn is the basis of all subsequent discipline specific mesh representations. A part can contain multiple representations.
        • Create Representations
        • Define Representations
          Create your own user defined representation. User defined representations are saved to the settings and will be available in subsequent HyperMesh sessions.
        • Add Representations
          Part representations can be added from external sources such as solver decks and HyperMesh binary files or from the Part Library.
        • Browse Library Content
          Review library content using the Library Viewer.
        • Load Representations
          Part representations can be loaded from your current HyperMesh session or from the Part Library.
        • Reload Representations
          Restore part representations to their original state.
        • Unload Representations
          Unload part representations from a session.
        • Update Metadata From PDM
        • Sync Metadata To PDM
          Sync PDM metadata (PDM PID, PDM Thickness, PDM Material, and PDM MID) based on a selected part or part's metadata (PID, Thickness, Material, MID).
        • Save Representations
          After importing a BOM and creating respective representations, you can save the representations locally or in the Part Library.
        • Delete Representations
          • Delete Representations from the Current HyperMesh Session
          • Delete Representations from the Part Library
        • Representation Load Settings
          Settings to configure the representation entity management behavior.
      • Manage Part Revisions
        Manage, control and update Major, Study and Library Part revisions using the Part Library.
      • Manage Configurations
        Group common and unique parts/part assemblies together in part sets, and organize parts and part sets that are unique to a configuration.
    • Manage Subsystems
    • PostgreSQL Installation and Configuration
      Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
  • Model Setup
  • Morphing
  • Optimization
    Setup an Optimization in Engineering Solutions.
  • XY Plotting
2021
  1. Home
  3. Manage Parts
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Crash
  • CFD
  • Drop Test
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
Index
