Graphical Manipulator
A graphical manipulator allows you to modify specific items directly in the graphics area using interactive tools.
Figure 1. Streamlines Graphical Manipulator Example
| Panel | Graphical Manipulator | Description |
| Section Cut | Single Direction/Arrow Three Directional |
These graphical manipulators allow you to modify the definition of the section. Section cuts defined by a specific plane can only be adjusted by moving the base point along the normal. Other section cuts can be translated or rotated anywhere in 3D space. |
| Streamlines | Line Two Directional Three Directional |
The streamline rake used to create streamlines is defined by seed nodes on a line, plane, or area. This line, plane, or area can be scaled, translated, or rotated using a manipulator specific to the rake type. |
Figure 2. Section Cut Graphical Manipulator Example
