HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
The steps to launch SnRD Post-processing module are mentioned
in the following section.
Launch HyperView 2021 from
installed location.
Select File > Load > Preferences.
Select Squeak & Rattle and click
Load. This creates SnRD menu in the HyperMesh
window.
Click Directors > SNRD
This will open the SnRD Post Processing tab in
HyperView as shown below. Figure 3.
The functions and operations to be done in each tab are explained in
the following sections. You have to start from Post
Processing tab to load the files and evaluate the
results.
Once SnRD Post tab is active, click against Model File.
A file browser option opens. Browse and select
Tutorial_IP_SNR_Model.fem from the folder which was created
during Process Parameters step.
Since the Pre-output CSV file is located in the same
folder, this will be picked automatically by SnRD.
After selecting the required files, click the required tab to continue with the
processing.
