/TH/TRUSS
Block Format Keyword Describes the time history for trusses.
| /TH/TRUSS/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| elem_ID | elem_name | ||||||||
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| elem_ID | Element
identifier (Integer) |
| elem_name | Name of the element to appear in the time history (Integer, maximum 80 characters) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| TRUSS | Trusses | OFF, F, IE, A, L, PLAS |
Table of Available Variables - Part 2
| Keyword | Variable group | Saved TH Variables |
| TRUSS | DEF | OFF, F, IE, PLAS |
Output for Available Material Law
| Output | Material Law |
| OFF: element flag for deactivation 2 | /PLAS_PREDEF, 1, 2, 44 |
| F: normal force | /PLAS_PREDEF, 1, 2, 44 |
| IE: internal energy | /PLAS_PREDEF, 1, 2, 44 |
| A: area | /PLAS_PREDEF, 1, 2, 44 |
| L: initial length | /PLAS_PREDEF, 1, 2, 44 |
| PLAS: equivalent plastic strain | /PLAS_PREDEF, 2, 44 |
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- OFF:
- 0.0 deleted element
- 1.0 active element
- 2.0 (shells / solids): active element using small strain
- Negative value -1/-2 when the element is on stand by due to rigid body
Some intermediate values can be found during few cycles before element deletion (progressive reduction of off during a few cycles applies as a multiplicative factor to the stress, so that the stress is progressively vanished and element is deleted after ~ 10 cycles). This process applies to some element types, but not all.
