*MAT_S08 (SPRING_INELASTIC)
LS-DYNA Input Interface KeywordThis keyword defines a nonlinear spring material with stiffness available only in tension or in compression.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_S08 or *MAT_SPRING_INELASTIC | |||||||
| mat_ID | LCFD | CTF | |||||
Definition
| mat_ID | Material identifier (Integer) |
| LCFD | Loading curve identifier: force vs displacement or moment vs
rotation angle. The curve should start with (0, 0) and be
defined in first quadrant only. (Integer) |
| CTF |
(Integer) |
- This keyword maps to /PROP/TYPE8 (SPR_GENE) spring using a default mass 2.0e-03 kg and inertia 2e-02 kg*mm depending on the units.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
