*MAT_083 (FU_CHANG_FOAM)
LS-DYNA Input Interface KeywordThis keyword defines an isotropic, highly compressible Fu Chang foam.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_083 or *MAT_FU_CHANG_FOAM | |||||||
| mat_ID | E | TBID | |||||
| HU | |||||||
| SHAPE | |||||||
Definition
| mat_ID | Material identifier (Integer) |
| Initial density (Real) |
| E | Young’s modulus (Real) |
| TBID | Table identifier for engineering stress vs engineering strain
for different strain rates. Positive strains and stresses
correspond to compression (Real) |
| HU | Hysteresis unloading factor 0<HU<1 (Real) |
| SHAPE | Shape unloading factor (Real) |
- This keyword maps to /MAT/LAW90.
- The unloading follows the first loading curve when HU=0. For HU>0, the first loading curve is used to calculate the unloading path based on a damage formulation.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
