MV-1050: Automate Using TCL
In this tutorial, you will invoke a TCL script from MotionView and link the script to a menu item on the menu bar.
Run the Script Manually
In this step you will run the simple_auto.tcl script manually in MotionView.
Create a Menu Item that Automatically Invokes the Script
In this step you will link the simple_auto.tcl script to a Menu Item on the MotionView menu bar.
