Global Block
The Global block contains settings for coupling the X, Y, and Z direction force computations and the X, Y, Z direction moment computations. This block is mandatory.
| Parameter | Type | Units | Description |
| EPSILON | Real | No-units | Unused at present. Ignore when reading file. |
| COUPLING | String | No-units | Valid choices are:
The following is an example of a Global block:
$-------------------------------------------------------------- GLOBAL
[GLOBAL]
COUPLING = 'spherical'
