Mount Limits Block
The [MOUNT_LIMITS] block stores the parameters for mount limits. You can use commas, white spaces or tab characters to separate the data values. The solver obtains the mount limits for a model through the IMPACT function. You can specify limits in the positive and negative travel directions for all 6 directions: X, Y, Z, AX, AY and AZ. For each direction, you specify five parameters.
The following table describes the type and dimension for the input parameters. Abbreviations are [A] = angle dimension, [F] = force, [L] = length, [T] = time.
| Parameter | Type | Translational Units | Rotational Units |
| K | Real | [F][L-1] | [F][L-1][A-1] |
| E | Real | - | - |
| C | Real | [F][T][L-1] | [F][L][T][A-1] |
| D | Real | [L] | [A] |
| L | Real | [L] | [A] |
The example below shows the specification of a Mount Limits block in the .gbi file:
$----------------------------------------------------- MOUNT_LIMITS
[MOUNT_LIMITS]
$ Direction K E C D L
IMPACT_PARAMETERS_TRA_X_POS = 1000.0 1.0 0.0 1.0 1.0
IMPACT_PARAMETERS_TRA_X_NEG = 1100.0 1.1 0.0 1.0 1.0
IMPACT_PARAMETERS_TRA_Y_POS = 1200.0 1.2 0.0 1.0 1.0
IMPACT_PARAMETERS_TRA_Y_NEG = 1300.0 1.3 0.0 1.0 1.0
IMPACT_PARAMETERS_TRA_Z_POS = 1400.0 1.4 0.0 1.0 1.0
IMPACT_PARAMETERS_TRA_Z_NEG = 1500.0 1.5 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_X_POS = 20000. 1.0 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_X_NEG = 21000. 1.2 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_Y_POS = 22000. 1.3 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_Y_NEG = 23000. 1.4 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_Z_POS = 24000. 1.5 0.0 1.0 1.0
IMPACT_PARAMETERS_ROT_Z_NEG = 24000. 1.5 0.0 1.0 1.0
