HyperWorks
HyperWorks
2021
  1. Home
  2. HyperWorks Tools
    Administrative tools to customize your HyperWorks installation.
  3. HyperWorks Verification and Validation Harness
    HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability, scalability, and robustness, and to gain more confidence in HyperWorks products.
  4. User's Guide
  5. HyperXtrude/HyperMold Manufacturing Solution Tab
    Use the HyperXtrude/HyperMold tab to compare FE model data, solutions, and results across HyperXtrude versions.
  6. FE Model Tab
  • What's New
  • Altair HyperWorks Introduction
  • Tutorials
  • HyperWorks Tools
Index
HyperWorks
2021
HyperWorks
  • What's New
    View new features for HyperWorks 2021.
    Quick introduction to Altair HyperWorks and its suite of products.
  • Tutorials
  • HyperWorks Tools
    • Altair License Utility
      The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted HyperWorks Units.
    • AbaqusODB Upgrade
      AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2016 (or earlier) to Abaqus 2021.
    • HvTrans
      HvTrans is a result translator for HyperView that translates solver result files to H3D files.
    • HyperWorks GUI Toolkit
      The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
    • Model Identification Tool
      The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
    • Register HVPcontrol
      Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
    • HgTrans
      HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
    • HyperWorks Automation Toolkit
      The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
    • H3D Validation Tools
      The H3D Validation Tools available in HyperWorks are H3D Info and H3D Validate.
    • HyperWorks Verification and Validation Harness
      • User's Guide
        • Module Menus
        • Batch Mode
          HVVH can be run in batch mode with a simple command line syntax using command line argument(s).
        • Design Tab
          Use the Design tab for a solver check run. Inspire (OptiStruct) is supported.
        • Pre-processing for CAD Modeling and Meshing
          Use the CAD and FE Model tabs to verify and validate CAD modeling and meshing.
        • Solution Tab
          Use the Solution tab for a solver check run and to submit a job (LS-DYNA, Radioss Block, and OptiStruct are supported).
        • Post-processing
          The solver output results are used for further design verification and validation. The accuracy of the results as processed, interpreted, and visualized by a post-processor is key. HyperView is used to post-process most of the solver(s) results. Use the Result tab to ensure that HyperView does not deprecate any result information after post-processing.
        • HyperForm Manufacturing Solution Tab
          Use the HyperForm tab to compare FE model data, solutions, and results across HyperForm versions.
        • HyperXtrude/HyperMold Manufacturing Solution Tab
          • FE Model Tab
            • Model Setup
            • Compare Basic Input and Output
            • Compare HyperXtrude Versions
          • Solution Tab
          • Result Tab
        • Auto Compare
        • Validate Tests
          Validation tests are used to execute user-defined verification script(s) in two different HyperWorks versions and compare the output files.
      • Reference Guide
      • Tutorials
    • Uninstall HyperWorks
      Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed files, or remove all the files that resides in the installation directory.
HyperWorks
HyperWorks
2021
  1. Home
  2. HyperWorks Tools
  4. User's Guide
  6. FE Model Tab
  • What's New
  • Tutorials
  • HyperWorks Tools
Index
FE Model Tab
  • Model Setup
