ACUSIM.DIR is the primary data storage directory for results from a
solution.
ACUSIM.DIR contains various files that completely define the
simulation, including results. The directory stores data in a variety of files, each
corresponding to a different type of output. These files should not be managed manually.
Rather, if you need to manage the
ACUSIM.DIR directory, see
Manage Files in ACUSIM.DIR.
| File Grouping |
File Extension |
Description |
| Auxiliary Files |
.slv |
AcuPrep solver input |
| Basic |
.cli |
Replicated .echo file |
.ddc |
Domain decomposition |
.oqi |
Mask information |
.top |
Solutions summary |
.dat |
Domain connectivity |
.osn |
Surface composition |
| Derived Quantity Output |
.odq |
| Nodal Output |
.out |
| Restart |
.rst |
| Time History |
.oth |
