Introduction to AcuSolve Tutorials
This guide contains a collection of simulation cases with explicit instructions for setting up, solving and post-processing. A range of tutorials are included to illustrate the basic AcuSolve workflow and to provide guidance for setting up a variety of problems.
Some tutorials can be completed with a choice of pre-processor. Therefore, four sets of tutorials are provided here: one for HyperWorks CFD, one for SimLab, one for HyperMesh, and one for AcuConsole.
Objectives
- Present the basic AcuSolve workflow.
- Introduce the capabilities of AcuSolve to new users.
- Provide guidance for the use of AcuSolve with industrial applications.
Prerequisites
No experience with AcuSolve is needed prior to running through the tutorials included in this guide. It is expected that you have some exposure to basic principles of engineering and computer-aided engineering.
For the HyperWorks CFD based tutorials, it is strongly recommended that you go through the introductory tutorial ACU-T: 1000 HyperWorks UI Introduction before proceeding to the other tutorials. This tutorial includes the steps to import the geometry model, define surface mesh controls and boundary layer parameters, and so on, which are not included in the subsequent tutorials. For these remaining tutorials, you will be provided a HyperMesh database (.hm file) which has the pre-defined mesh controls. Instructions related to post-processing have been included in all the tutorials.
For the SimLab based tutorials, it is recommended that you go through the introductory tutorial ACU-T: 1000 HyperWorks UI Introduction before proceeding to the other tutorials. This tutorial provides an overview of the panels, ribbons, and toolbars in the SimLab user interface followed by demonstration of the CFD workflow. All the SimLab tutorials start from importing the CAD geometry, generating mesh, and setting up the simulation to post-processing the results. All the tutorials are video-based and you need to have an internet connection to view the videos and to download the files.
For HyperMesh based tutorials, the introductory tutorial ACU-T: 1000 HyperWorks UI Introduction provides the instructions for setting up CFD simulations in HyperMesh starting from geometry import through post-processing. The subsequent tutorials do not have the steps related to geometry import and mesh generation. For these tutorials, you will be provided with the model HyperMesh database (.hm file), which has the meshed geometry. The tutorials then provide instructions related to CFD set up and post-processing.
For AcuConsole tutorials, it is strongly recommended that you complete ACU-T: 2000 Turbulent Flow in a Mixing Elbow prior to running any of the other tutorials. This tutorial walks you through the basic simulation workflow and the use of AcuConsole.
Basic Workflow
HyperWorks CFD Based Tutorials
- Problem description
- Start HyperWorks CFD and open the HyperMesh database
- Validate the model
- Set up the simulation parameters and solver settings
- Assign material properties to the fluid and solid regions
- Define any porous media, body force, and/or reference frames
- Assign flow boundary conditions, such as inlet, outlet, slip, symmetry, and so on
- Define any radiation parameters
- Define any mesh motion and mesh boundary conditions
- Define surface mesh controls, boundary layer and volume mesh controls, and generate the mesh
- Define nodal output frequencies, surface and volume monitors, and nodal initial conditions
- Compute the solution using AcuSolve
- Post-process results with the plot utility (to visualize data related to the progress of the calculations) and/or with HyperView to visualize simulation data with contours, vectors, streamlines, and the like
SimLab Based Tutorials
- Learning outcome
- Select the physics to be solved
- Post-process results (to visualize data related to the progress of the calculations and/or to visualize simulation data with contours, vectors, streamlines, and the like)
- Summary
HyperMesh Based Tutorials
- Start HyperMesh and import the model database
- Set up the general simulation parameters
- Specify the solver settings
- Define the body force, material models, multiplier functions, emissivity models, reference frame, mesh motion, and so on
- Set up the surface boundary conditions, such as inlet, outlet, wall, and so on, and assign material model parameters to volume regions
- Specify the nodal initial conditions, reference pressure, and so on (if needed)
- Post-process results with AcuProbe (to visualize data related to the progress of the calculations) and/or with AcuFieldView to visualize simulation data with contours, vectors, streamlines, and the like
AcuConsole Based Tutorials
- Analyze the problem and identify the important attributes that need to be provided to AcuSolve
- Start AcuConsole and create the simulation database
- Set general simulation attributes
- Set solution strategy attributes
- Set material model attributes
- Import the geometry for the simulation
- Apply attributes to volumes
- Create surfaces, such as inlet, outlet, and wall, and apply boundary conditions
- Set global meshing attributes
- Set user-defined zones for mesh refinements to areas not linked to a particular surface
- Set surface meshing attributes
- Generate the mesh
- Run AcuSolve to calculate the solution
While all steps needed to complete these tutorials are explicitly mentioned, default values, initial conditions, and discussions of other turbulence models are intentionally left out of the tutorials.
For tutorials that illustrate more complicated problems, such as those involving transient physics or mesh motion, details of additional tasks are provided in the tutorial.
Supporting Files
Supporting files are provided for completing the tutorials. These files are located in a compressed .zip archive located in the <hwcfdsolvers installation directory>\acusolve\win64 (or linux64)\model_files\tutorials\AcuSolve directory.
Copy the following zip files to a local directory and expand their contents.
| AcuConsole tutorials | AcuConsole_tutorial_inputs.zip |
| HyperMesh tutorials | HyperMesh_tutorial_inputs.zip |
| HyperWorks CFD tutorials | HyperWorksCFD_tutorial_inputs.zip |
You will need to know these locations in order to load files for any given tutorial.
For SimLab, you can download the files using the links provided on the page for each tutorial.
Typographical Conventions Used in this Manual
| Set the Turbulence equation to Spalart Allmaras. |
| Enter Symmetry as the name of the surface. |
| Open and set the view to +Z. |
This indicates that the View menu is clicked, then the Defined Views menu item is selected, and that the button labeled +Z is clicked when the dialog opens.
| Expand the tree item. |
This indicates that first the Model tree item is expanded, then the Surfaces item underneath it is expanded, and finally, the Small Inlet item under Surfaces is expanded.
