MotionView
MotionView
2021
  1. Home
  2. MotionView Overview
    MotionView is a general pre-processor for Multi-body Dynamics.
  3. Model File Management
    Open and save model files, import/export models, and import/export a solver deck.
  4. Importing and Exporting a Solver Deck
  • What's New
  • Get Started
  • Tutorials
  • MotionView Overview
  • MotionView Menus
  • Project Browser
  • MotionView Panels
  • MotionView CAD Interfacing
  • Flexible Bodies
  • MotionView Solver Interfacing
  • Vehicle Modeling
  • Optimization
  • Functional Mockup Unit (FMU)
  • MotionView Interface with Collaboration Tools
  • Tcl/Tk Reference Guide
  • MDL Reference Guide
  • MotionSolve Reference Guide
  • Templex and Math Reference Guide
  • MotionView Python Reference Guide
  • HyperWorks MotionView Help
Index
MotionView
2021
MotionView
  • What's New
    View new features for MotionView 2021.
  • Get Started
  • Tutorials
    Discover MotionView functionality with interactive tutorials.
    • Using MotionView
      Learn more about using MotionView.
    • End User Workflow
      A multibody system study generally involves the following broad steps. The following sections give a brief introduction on using MotionView and the related HyperWorks products to conduct such a study:
    • Model File Management
      • Opening and Saving a Model File
        MBD model files are files written using the Model Definition Language (MDL). These model files (*.mdl) can then be opened and saved in MotionView.
      • Importing and Exporting Models
        The import feature facilitates reading in systems from the wizard library, or the MDL data statements (properties), or a combination of the two using an MDL file. The export feature facilitates exporting wizard selection choices in the existing model and/or the MDL data statements (properties), or a combination of the two into an MDL file.
      • Importing and Exporting a Solver Deck
        • Importing a Solver Deck
        • Export a Solver Deck
        • Load an ADAMS *.adm File
    • Container Entities
      MotionView supports and encourages a modular model building approach. Different entities can be aggregated into containers, thereby arranging a model into a collection of different assemblies or sub-systems.
    • Model Entities
      Learn more about MotionView model entities.
    • Collectors
      A collector is a yellow button on a panel that enables you to select an entity type either graphically or from the topics/motionview/collectors_select_entity_dialog_r.html.
    • Data Entry
      Explore data entry in MotionView.
    • Use the Expression Builder
      The expression builder allows you to enter expressions in text boxes without extensive typing and memorization. It can be used to construct mathematical expressions that are a function of the model parameters.
    • Select an "Entity" Dialog
      The Select an "Entity" dialog allows you to change the entity in a collector.
    • SolverMode
      MotionView contains an implicit variable called SolverMode. In MDL, SolverMode can be used in an "if" context to define topology (include Templex templates). MotionView retains the "if" result for both cases so that when you toggle the solver type, the associated text becomes active within the user interface.
    • MotionView in Batch Mode
      Batch mode allows you to generate a solver input model file from an MDL model file and run the solver job without starting the MotionView user interface.
  • MotionView Menus
    Explore the MotionView menus which provide access to the various wizards, dialogs, tools, and panels.
  • Project Browser
    The Project Browser allows you to view the MotionView model structure while providing display and editing control of entities.
  • MotionView Panels
    Explore the various panels and tools in MotionView.
  • Flexible Bodies
    MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    Solvers and translators supported in MotionView.
  • Vehicle Modeling
  • Optimization
    Discover optimization with MotionView, MotionSolve, and HyperStudy.
    Use the FMU tool to add a Functional Mock-up Unit and connect it to a multi-body model.
    MotionView supports a limited version of interface with HyperWorks Collaboration Tools.
    Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    MotionView help for HyperWorks.
MotionView
MotionView
2021
  1. Home
  • What's New
  • Get Started
  • Tutorials
  • MotionView Menus
  • Project Browser
  • MotionView Panels
  • Flexible Bodies
  • Vehicle Modeling
  • Optimization
Index
