hgtrans control SetOutputFile
Sets the output file name.
hgtrans control SetOutputFile filename
HyperGraphTrans Tcl Modify
This command sets the name of output file that will be used as the target for the translation process. The output file is always written in the Altair Binary Format (ABF). If the file already exists, it will be overwritten.
- filename
- Filename must be the path name of the file to write.
Context
hgtrans control SetFile “ANGACC”
hgtrans control SetOutputFile “ANGACC.abf”
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
An error will be reported during translation if the file is not writeable.
Keywords
set output file
