hgtrans control SetFile
Sets the input file name.
hgtrans control SetFile filename
HyperGraphTrans Tcl Modify
This command sets the file that will be used as an input for the translation process.
- filename
- Filename must be the path name of a file of a supported format.
hgtrans control SetFile “ANGACC”
hgtrans control SetOutputFile “ANGACC.abf”
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
An error will be reported during translation if the file is not present or not supported.
Keywords
set input file
