hm_setcommandposition
Sets the position of the command window.
hm_setcommandposition position
HyperMesh Tcl GUI Command
This command sets the position (top | bottom) of the command window. If the command window is not currently visible, it will not be turned on.
- position
- The position of the command window. Valid values are top and bottom.
hm_setcommandposition top
# Handle error
}Version History
9.0
2021 - Deprecated in HyperWorks but continues to be supported in HyperWorks Desktop.
