hm_posteeforentity
Posts a pop-up for a selected entity.
hm_posteeforentity entity_type entity_id ?title? ?modal? ?disable_create_edit?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to post the editor for.
- entity_id
- The ID of the entity to post the dialog for.
- title (optional)
- Specifies the title of the dialog. The default title is Entity Editor.
- modal (optional)
- Specifies whether the dialog is modal (1, default) or not (0).
- disable_create_edit (optional)
- Specifies whether to disable the Create and Edit context menu items (1) or not (0, default).
To display an for the component with ID 2:
hm_posteeforentity comps 2
# Handle error
}Version History
13.0
