*subsystemconfigurations()
Creates a subsystemconfiguration in HMASCII format.
*subsystemconfigurations (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the subsystemconfiguration.
- name
- The name of the subsystemconfiguration.
- color
- The color of the subsystemconfiguration. Valid values are 1-64.
*subsystemconfigurations(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2020
