*alereferencesystemnodes()
Creates an alereferencesystemnode in HMASCII format.
*alereferencesystemnodes (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the alereferencesystemnode.
- name
- The name of the alereferencesystemnode.
- color
- The color of the alereferencesystemnode. Valid values are 1-64.
*alereferencesystemnodes(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2019
