Manage the Legend Display
Open the Tensor panel in the following ways:
- From the Results toolbar, click Tensor
. - Select Plot > Tensor from the Results menu.
From the Tensor panel, under Legend threshold, activate the
Max check box and enter the value to be assigned to
the highest color in the contour plot.
The new value is also changed in the Values section of the Edit Legend dialog.Note: If a value entered for threshold Max is invalid, it will not be applied and the panel will be updated to reflect the actual state.
Activate the Min check box and enter the value to be
assigned to the lowest color in the contour plot.
The new value is also changed in the Values section of the Edit Legend dialog.Note: If a value entered for threshold Min is invalid, it will not be applied and the panel will be updated to reflect the actual state.
- For Multiplier, enter the multiplier for scaling all the result values.
Click the Edit Legend button.
Opens the Edit Legend dialog, where you can change legend properties.
