Select a Projection Rule
Open the Contour panel in the following ways:
- From the Results toolbar, click Contour
. - Select Plot > Contour from the Results menu.
From the Contour panel, click the Projection Rule
button.
The Projection Rule dialog is displayed.
Select the primary and secondary axes from either the global or user-defined
system (selected for Resolved in).
When the primary axis is perpendicular to the shell plane, the secondary axis is used.See the Projection Rule topic for additional information.
