HyperView
HyperView
2021
  1. Home
  2. Results
    Explore the various result plotting tools.
  3. Contour
    Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
  4. Create and Manage Contour Plots
    Learn about creating and managing contour plots.
  • What's New
  • Get Started
  • Tutorials
  • Display/Visualization
  • Model
  • Results
  • Annotate Model Results
  • Tools Menu
  • Preferences Menu
  • Aerospace Menu
  • NVH Menu
  • Vehicle Safety Tools
  • Upfront Data Loader
  • HyperView Solver Interfacing
  • HyperWorks HyperView Help
Index
HyperView
2021
HyperView
  • What's New
    View new features for HyperView 2021.
  • Get Started
  • Tutorials
    Discover HyperView functionality with interactive tutorials.
  • Model
    Create and import/export sets, create user defined coordinate systems, or use the symmetry visualization tool.
  • Results
    • Contour
      • Create and Manage Contour Plots
        • Create a Contour Plot Based on Nodal Results
        • Create a Contour Plot Based on Elemental Results (Including Corner Results)
        • Change the Display Options
        • Manage the Legend Display
        • Overlay Result Display
        • Clear Contour
        • Create Plot Style
        • Control the Display of Iso Values
        • Select a Projection Rule
        • Query Results
      • Color Band Generation
        A contour plot generates color bands on the model, based on the values found in the results file.
      • Additional Comments
      • Layers
        Layers allow you to display a contour for a specified element layer when a layer definition is available for an element.
      • Value Filter
        The Value filter available in the Contour panel allows you to specify threshold criteria for processing results only in a specific range.
      • Composites Post-processing
        Composites post-processing is enhanced in HyperView with the reorganization of ply results as layers.
      • Cache Results
        After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add the currently active contour result to an internal cache.
      • Mid-side Node Elemental Results in Contour
        Mid-side nodes refers to the nodes in between the corner nodes of the 2nd order elements.
      • Post-process Abaqus Stress Results
      • Post-process Stress Results (solver independent)
    • Iso
      Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
    • Vector
      Use the Vector tool to set options for a vector plot.
    • Tensor
      Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
    • Edit Legend
      The Edit Legend dialog allows you to change the legend properties.
    • Graphical Editing of the Legend and Iso-slider
      You can edit the contour, vector, or tensor plot legend in the graphics area.
    • Complex Results
      Results in some analysis types come as complex numbers.
    • Computed Results
      A listing of results that are computed in HyperView.
    • Nodal Averaging of Elemental Results
      Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
    • Averaging Options
      The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
    • Multi-model Result Plotting
      HyperView allows for plotting (contour, iso, vector, or tensor) across multiple overlaid models.
    • Animation Types
      HyperView's animation functions allow you to view your model in motion. The three types of animation include transient, modal, and linear static.
    • Deformed
      Use the Deformed tool to specify parameters for deformation display.
    • Derived Load Cases
      The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
    • Tracking
      Use the Tracking tool to track any entity during animation.
    • Query
      Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
    • Systems Review Dialog
      Use the Systems Review dialog to review the orientations of various element systems (1D, 2D, or 3D), as well as material and ply systems.
    • Free Body Diagrams (FBD)
      The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
    • Extract and Linearize
      Starting in version 2021, the Stress Linearization tool has been renamed as Extract-Linearize and will support both the Extract Data and Stress Linearization methods.
    • HyperWorks Result Math
      A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
    • CFD Post-Processing
      HyperView offers CFD post-processing capabilities for a large class of industrial applications.
    • Fatigue Manager
      The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that can be used to set up a fatigue analysis.
    • Fatigue Configuration File
      The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
    Annotate model results using the Measures, Notes, Tracing, Image Planes, and Build Plots tools.
  • Tools Menu
    From the Tools menu, you can access various panels and dialogs.
  • Preferences Menu
    From the Preferences menu, you can define file export settings and access the Options dialog.
  • Aerospace Menu
    The Aerospace menu provides you with access to various aerospace tools.
  • NVH Menu
    The NVH menu provides you with access to various NVH utilities.
    The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
    A new workflow emphasizing upfront data loading for standard crash post processing use cases.
    Supported solvers in HyperView.
    HyperView help for HyperWorks.
HyperView
HyperView
2021
  1. Home
  2. Results
  3. Contour
  • What's New
  • Get Started
  • Tutorials
  • Model
  • Results
  • Tools Menu
  • Preferences Menu
  • Aerospace Menu
  • NVH Menu
Index
  • Clear Contour
  • Create Plot Style
  • Query Results
